O.K. Novice here. I hope this is the proper forum for this. If not, sorry
and please just move it.
Now, I searched and found some threads on these sort of inquiries but they were rather technical (file formats, etc...) so I am posting, hoping to get a more simplified answer (if there is one).
First, here's the hardware that I have/will have:
NEC ND-1100A DVD+RW Burner
Reads/Writes to DVD+RW
Also Reads DVD+R, DVD-R, DVD-RW, etc....
Panasonic DMRE-30 DVD-RAM/DVD-R Recorder
Reads/Writes to DVD-RAM, DVD-R, etc...
Samsung DVDV-2500
Reads DVD+RW, DVD-R, etc...
The DVDs referred to below will not be copyright protected.
Now my questions:
First scenario
Can I copy a DVD-R disc (produced on the E30) onto my PC's hard drive by reading it in my 1100A? In other words, as my 1100A can read it, can I copy what it can read to my hard drive?
If so, can I then use software to edit, dub, alter, etc... and then convert the final content to a format that I can then burn to DVD+RW using my 1100A burner.?
Second scenario
If I produce a DVD+RW on my 1100A burner, I can play it
on the V2500. Can I then copy it to my DVDR (E30) if they
are hooked up together?
Thanks in advance,
James
Mississauga, Ontario, Canada -
1.) Should normally be possible but in some ways impossible. It depends on the record-functions or extras you use with your e30.
The format of the files should be a mpeg2 compliant so there is no big work to convert them, if you have to do that... But I have no standalone dvd recorder - I just figured out the facts from posts I've read in forums.
2.) Is not possible, cause your e30 doesnt work with external/other devices. Brand new recorders have such a connection/function, but your e30 doesnt.
Correct me if I'm wrong. -
Thanks for the reply [_chef_].
1) Not sure what you mean. Are you trying to confuse me? LOL!
2), I think I phrased that question incorrectly. What I meant by "hooked up together" is that both units would be connected to my HDTV (all 3 pieces connected together). So I would be playing the DVD+RW on the V2500 (viewing it on the TV) and copying it (from the HDTV) to my E30. I'm not sure how they are connected to the TV, but I gather it would be the same set up like people do to copy VHS to DVD. I guess another way to ask is, is my E30 copying only the content from the TV, or does the format that the DVD disk in the V2500 is in come into play?
Thanks,James
Ah, good.
Scenario 2 should be working for real. Only if your DVD+RW source has a copyprotection/macrovision and your players macrovision is enabled too it would not work.
And 1, I tried to say when you are using normal recording functions then it will work 100 pro.
Maybe you can find more infos about your e30 here - just try the search function.
Hope not to confused you too muchwell.
Thanks again!
Yes, I have been looking in all the different forums and there
is a wealth of info. Just have to fine the time to read it all. LOL!
Playing around with the saerch function too.
Glad I found this site.James
Look around in these forums!!
1) www.mediaforums.net
2) www.firmware-flash.com
Both are great! 8) -
Thanks again!
Lots of great stuff there too.
Looks like I will have a lot of printing to do at work tomorrow. LOL!James
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 12:35 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 14:53 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14 -
Daytek DVDR-P30 what brand DVD+R do you use? my HP 16x DVD+R don't work
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 5Last Post: 19th Oct 2007, 22:22
