  1. Hi,
    I am using tmpenc 2.59.47.155 to convert my avi to dvd.
    I converted them successfully to m2v and wav files.
    But now I found out that I didnt do a good job cropping the film and the right side has a black line.
    I try to reencode the file using tmgpenc, but tmgpenc cant read them now
    Is there a way to recovert them to something tmpenc can read so I can recrop crop the film or do I have to recapture the video again?
    Thanks for any help.
    Arthur
  2. No can do with tmpgenc. Besides the quality is not what you want and you will then just get "garbage in/garbage out." You will have to start from the beginning. Next time, only do a couple of minutes of encoding, and check it to make sure it is right, and then when satisified, do the whole thing.
