How dangerous is flashing firmware? Is it fixable if I mess up? Will reformating fix a mess-up?
If the player is not total crap, and if the probability of power cuts is low, there's generally not much that can go wrong, provided you make sure the Firmware is for your model. However any player that isn't (see above) should not accept any firmware not inteded for it.
So basically the only real problem should be power cuts. And even if it does go wrong, any good repair shop should be able to fix it.--
Linards
LG RH7823W Firmware?
By grungerock in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th May 2010, 00:11 -
LG RC-7000 Firmware need
By michael chiklis in forum DVD & Blu-ray RecordersReplies: 0Last Post: 3rd Jun 2009, 11:51 -
Where to Get Firmware Update
By Teac23 in forum ComputerReplies: 1Last Post: 26th Apr 2009, 14:52 -
How to modify firmware
By torrentkid in forum DVD & Blu-ray PlayersReplies: 5Last Post: 14th Apr 2009, 12:44
