I am quite curious on the double density CD-R discs which hold 1.3 gigs. Sounds like a double sided 650mb disc. Anyone ever use these? More importantly are these 1.2 mm thick?? They seem interesting, I wouldn't mind having to flip over the disc if it were like that. Even nicer if it is in CD-RW. Oh I saw these on the Sony website. The double density seems to be similar to the 9.4 gig DVD-R, which is double sided. Any ideas on if it is widely supported? Comments welcome!
-TIA
they only work in the drive they were burned in....and probably won't be supported by anyone else as there is really no point as DVD burners are getting so cheap these days....4.7GB beats 1.3 anyday 8)
I agree. There will be no point in getting that. and besides, I don't think they'll last long on the market compeeting with dvd capacity.
Get dvd burner instead.
=[ vinchi007 ]= -
BTW, the way they got 1.3 Gig on the disks was to wind the data track tighter in the disk.....you could think of it as a bigger version of the 90 and 99 minute CD-R's, rather than some sort of DVD technology.
They are not double-sided. They look for all the world like ordinary CDs.
However, they are not "CDs". They cannot be read by ordinary CD players and can only be written to by the Sony DD-CD drive.
As they use a different burning method, you cannot make audio CDs or VCDs on them. Only DATA discs.
Regards.Michael Tam
w: Morsels of Evidence
Increase the density of keyframes
By Stasik0 in forum EditingReplies: 11Last Post: 6th Jul 2010, 08:15 -
HP DVD+R Double Layer Discs
By SEE_Studios in forum MediaReplies: 57Last Post: 15th Apr 2010, 09:56 -
Why Don't Double Layer Discs Work?
By GordRocks in forum MediaReplies: 14Last Post: 10th Feb 2010, 09:16 -
Double sided discs
By brainoverload in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2008, 11:15 -
pioneer dv 470 and double layer discs
By SquireC in forum DVD & Blu-ray PlayersReplies: 2Last Post: 23rd Dec 2007, 05:09
