I am having real problems playing my avi's at decent quality. Before, the an avi would look very good, close to dvd even, and now would have artifacts everywhere. The various divx codecs i installed must have been the problem, so i tried removing them all.
Through the add/remove programs menu, i removed anything divx related and also nimo codecs pack. I use dvd2svcd in combination with CCE 2.5, and reinstalled those two too. But still, when I go to system properties, then video codecs, a bunch still appear, including divx 5.01 and 4.11. I tried removing them from there and it gave me a warning but I proceeded anyways. Upon returning to the system properties, I found that windows seems to have replaced it.
I really would like to wipe the codec slate clean and play everything at good quality again- any suggestions?
Thanks,
Octavian
By the way, this occurs when I play the avi's in both powerdvd and wmp.
The poor viewing quality produces worse quality svcd's too. -
yeah i wanna know too. i had to restore my pc cuz that divx 5 fucked up my avis. they were good then when i installed 5 it gave me all these artifacts.
not sure how to do it in ME or XP but...
in 98 you can go to Control Panel > Multimedia > Devices > Video Compression Codecs, highlight the one you want, click Properties and Remove.
in 2000 it's Control Panel > Sounds and Multimedia > Hardware > Video Codecs, click Properties, go to Properties tab, highlight the one you want and click Remove. -
a lot of codecs dont show up in the control panel .. use this app which also can unreg them
http://www.analogx.com/contents/download/audio/dxman.htm
Panasonic DV codec - removal? -II-
By ledishis in forum TestReplies: 3Last Post: 10th Dec 2011, 07:44 -
Watermark removal
By Shrimpy72 in forum ffmpegX general discussionReplies: 3Last Post: 14th Jan 2011, 11:31 -
By terrypin in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2009, 06:19 -
WMP CP removal
By kookie2000 in forum AudioReplies: 2Last Post: 14th Jan 2008, 16:41 -
complete audio removal
By pabloj240 in forum AudioReplies: 1Last Post: 23rd Jul 2007, 00:51
