insomnia region 1 WS
used pretty new version of dvddecryptor (ver 3.0.0.11) to rip, removing any multi-angles. then, i tried using 2 different versions of dvd2avi to frameserve (really old one and the latest stable version).. but both had audio sync problems
any1 else experience this?
I used SmartRipper and did not have synch problems.
Morloc -
I did the Pan&Scan version.
The audio was 20seconds of until i used a stripped version I
made with ifoedit (only select the main movies vobids.) -
Problems with insomnia?
Try to install noise-reduced fans into your PC for those overnight encodes... or move the box out of the bedroom if you can
Linards
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
