Does anyone know why I would suddenly get choppy stuttering MPG2 captures with this card. It just happened suddenly IE it used to work OK, I can still capture in MPG1. My intent is to capture from an analog camcorder and convert to SVCD with TmpGenc. Should I take a different approach, install new drivers, codec or what? I have made a couple of succesful SVCD's before so I'd like to continue with the same process without having to buy additional software.
Experiment with custom presets, ie you can edit your MPEG1 capture preset, and change it to MPEG2, maybe lowering the motion estimation settings (sounds like you're dropping frames).
Also, it may be a good idea to upgrade to MMC 7.7.0.1 if you can (or at least 7.6). -
It seems I can't run any higher version of MMC than 7.2 with XP and AIW Pro.
I know it used to work with the same capture settings. I have a development now, though, I installed MGI Video Wave (came with new purchase of Sony MiniDV camcorder), and now thec apturing works fine with ATI. Is that because MGI installs an aditional CODEC? However, now when I go to open an MPG2 file with TMPGenc it just crashes. This is very frustrating, but I think the way for me to go is to use the pass thru on the Sony MiniDV. Though I guess I could probably use the ATI AIW to capture to AVI, which TMPGenc should still be able to handle(?)
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum Capturing and VCRReplies: 15Last Post: 1st Jan 2011, 18:41 -
Sound with ATI AIW 9800 Pro
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 8th Aug 2010, 06:02 -
Weird Interference ATI AIW Pro
By Tom Saurus in forum ComputerReplies: 8Last Post: 7th Aug 2010, 09:52 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 11:26 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 15:36
