i have a wav that i extract from an avi with 23.97 fps and whanted to
resample it to 25 or 29.97 fps,
1) where do i need to go in cooledit to change to size of the file (speed it up)
2) is there a fourmula how much do i need to speed up the for each format ??
10x
The whole process is actually quite easy. First, divide the number of frames by the target fps rate and write down the result. Open the file in CoolEdit (I strongly recommend to work with uncompressed pcm wav files and disable the undo option under the edit menu). Then, under the transform menu select Time/Pitch and then Strech, and write the result from before in the length box (pay attention that this should match the length of the fps converted movie), don't change anything else, not even the precision setting because I didn't notice any major differences and it just taked a lot more time. Prees ok and wait, when the transform completes save your file to a pcm wav and you're done!
mp4.2000
By diesellam in forum Newbie / General discussionsReplies: 4Last Post: 5th Jul 2010, 12:43 -
Winfast tv 2000 xp
By Haopengyou in forum Capturing and VCRReplies: 5Last Post: 21st Jun 2010, 12:38 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30 -
Windows 2000 question.
By AlecWest in forum ComputerReplies: 34Last Post: 1st Jun 2007, 17:54
