I just recently bought an ATI All in Wonder 7500.
I tried installing the software that came on the CD. When I start my PC it gives me the following errors:
"Q298759 update not for this version of windows"
"AtiSServ Failed to provide required interfaces!"
"Unable to load language resources. Please re-install the software."
I downloaded the latest multimedia center from ATI. When I try to install the DVD software it says I need to enter the Serial number from my disk (180-xxxx-xxx), when I enter the serial number from my CD it says something like "Invalid, must have CD with DVD".
So I tried skipping the DVD and just installing the MultiMedia 7.6 software, it says that a previous version of MMC was detected, remove old version first. I have gone through the add/remove programs and removed the old multimedia software (that never worked to begin with), I went through the registry and deleted anything I found dealing with ATI. I tried installing the downloaded software and it still says an old version was detected. What else needs to be uninstalled, does the new ATI 7.6 multimedia software work???????
Any suggestions????
