    Dec 2002
    Portugal
    I've put a similar question in NEWBIE section but ... no answers
    Here is the problem:
    After capturing a video from my DV Cam PAL System I encode it with TMPG and I obtain a SVCD that I burn with Nero. Playing it on my Pioneer DVD player I can see it on my 4:3 TV with 2 black bars and reasonable quality 8) . BUT ... the image is shortened What is the problem?
    Also I still not understand the Video and Advanced tabs on TMPGenc. Which one is for the video input and which one is for the mpg2 video for output?
    Another question, please: dp I need to encode interlaced or non-interlaced to see the movies on my TV?
    JorgeC
    Apr 2002
    The State of Frustration
    Remember to TMPGEnc's SVCD's template to make your SVCD file before letting NERO burn it.
    Hello.
    Dec 2002
    Portugal
    But I use TMPG SVCD template!!! And I encode as COMPLIANT at Nero!!
    JorgeC
    Dec 2002
    Portugal
    After many hours finally I get a way to turn my videos to SVCD without distortions playing them on my Pioneer DVD player and 4:3 TV. Well, really they are XSVCD. I use TMPGEnc with: output Video aspect ratio:16:9 display (size 480x576), Advanced source aspect ratio of 4:3 625 line (PAL) and full screen (keep aspect ratio 2). Unfortunately I still get 4 black bars around the video (2 at top and bottom and 2 on each side) but the video is not distorted and has very good quality.
    Does someone understand this?
    JorgeC
    I had the exact same problem with my pioneer dvd player. I can not totally remember how I fixed it though. I believe I encoded normal 4:3 using tmpgenc but I had to switch the dvd player to 4:3 pan and scan or something like that. It was definately a setting in the dvd player and then all was fine.
  6. I think I am a little bit lucky. I don't see the black bars, but the movie paused at each section even I turned the PAUSE to 0, has any one experienced this?
    Dec 2002
    Portugal
    Yes, first I did also PAN & SCAN on DVD player but I realized that the image was truncated!
    JorgeC
