Hey guys,
The VCDHELP java calculator works really well. Is there a way to mod it or is there a program which can do exactly the same thing, but change the values to DVDR Settings?
For some movies which are too large, it would be nice to set values like the VCDHELP java calc, and get a max and adverage out of it.
Thanks!
Trenton_net wrote.....
Hey guys,
That calculator does give you and average and maximum birate for VCD/SVCD/DVD formats.
Just enter the length of the film in the time and sec windows it will calculate your average and max birate for you.
I used to use it all the time when i used TMPEGnc for my SVCD conversion's.
Now i just use DVD2SVCD, with it set up for DVD encoding. -
Well ok, What is the limit on bitrate drop untill you will notice quality problems with DVD resolutions? At what max level will quality level off at?
For a 120 min movie, the calculator shows an adverage of 4000 or so and a max of 9000 or so. It seems to me the bitrate would be all over the place. 4000 seems low for a DVD source (on adverage) but if the original movie fits on 4.7 gigs, they must have done the same thing.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 12:35 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
