Hi
I have been using PowerVCR2 for a while.
I like the results I get and others I have sent samples say they look great.
I am just puzzled by one thing.
If I capture using PowerVCR2 I use an edited DVD Pal profile.
If I capture at 8000 played back averages 6500 bitrate.
If I capture using PowerDirector 2.5 Pro same bitrate and settings playback bitrate averages 7900. Filesize is bigger too.
If I capture using WinDVR2 same resolution and bitrate, playback bitrate averages 8050.
I get good results with all three. but could someone explain why the PowerVCR2 file has such a low average bitrate??? I prefer this program out of the 3 of them.
Cheers
Fozzee
Come on guys
Thought we had some knowledgable people on this site.
DON'T PROVE ME WRONG
Cheers
Fozzee -
It may have something to do with the VBR mode used. If you can't see any difference in quality, then the smaller file is better.
Are u saying PowerVCR captures at a variable bitrate by default?
I don't think there is any option to turn this on or off ??
Fozzee
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 16:01 -
Video Capture software question
By kgingreen in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2010, 14:07 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 20:26 -
Question about software for K-World Video Capture Card
By cooper101 in forum Newbie / General discussionsReplies: 10Last Post: 31st Oct 2007, 14:49 -
After DVD playing software with BITRATE DISPLAY
By StuR in forum Software PlayingReplies: 5Last Post: 15th Aug 2007, 09:38
