The more I read about conversion, the more I learn, and the more I get confused.
I have a bunch of VHS and Hi8 tapes that I'd want to convert to digital for video editing. So here is my question:
From what I've read, to simply convert analog tapes to digital I believe I can use a digital converter such as Canopus 100 or Dazzle Hollywood Bridge, this would be one method of conversion.
The second method would be to capture and record the analog tapes directly into a digital camrcorder, right?
Since most digital camcorders have the ability to convert analog tapes into digital format, why would I want to use a digital converter in the first place? My only guess would be to save time if the conversion is directly captured into the hard drive vs transfering analog tapes into a digital camcorder and then transfering the tape into the hard drive. Does this make sense? Any help is greatly appreciated it.
thanks, al![]()
You got it right, just pick your poison; Analog tape--Digital Tape--computer
or, Analog tape--converter--computer. -
Actually, many camcorders do not. Most Sony digital camcorders do (except the TRV-140). Many Canon models also do. But many companies do not have it (most JVC models do not have a "video in").Since most digital camcorders have the ability to convert analog tapes into digital format,
Essentially, you want to make sure that your digital camcorder has a "video in" or, better yet, a passthrough feature. The passthrough feature allows you to capture VHS and other analog sources with your camcorder and pass it through directly to your computer (without having to record to a miniDV tape). -
Hi, Can you tell me if the CANON MV530i has the pass through ability and are the files going into the computer AVI, MPEG 1, MPEG 2 etc?
Thanks"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
Am totally confused with dvd film conversion.
By frenchman96 in forum Video ConversionReplies: 6Last Post: 10th Nov 2010, 10:38 -
Confused about 1080p
By gauche in forum Newbie / General discussionsReplies: 4Last Post: 18th Jan 2009, 09:51 -
Still confused on upconverting
By glp103 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jan 2008, 17:42 -
Really confused about resolutions....
By sam9s in forum DVB / IPTVReplies: 6Last Post: 12th May 2007, 13:42
