On my PC, i had a CD Rom and CD Writer, I have swapped the cd rom for a DVD Rom and only the DVD Rom shows up. What has happened to the cd writer
The first thing I would check are the master/slave jumpers. Make sure one drive on the cable is set master and the other slave.
That's probably it if there is no sign at the very beginning when it checks your ram and lists your hard and cd drives.
And just make sure your cable and power are connected well.
Then maybe your cmos has a hard drive auto detect you can do.
If it's just missing inside windows, maybe boot in safe mode, go to the device manager and delete the old cd rom you have removed. -
How do i put one on master and one on slave
DVD writer doesn't work
By kamyogi in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Apr 2011, 10:43 -
Why wont subtitles work?
By .deathnet in forum SubtitleReplies: 2Last Post: 3rd Mar 2009, 12:01 -
My HP DVD Writer 840x Wont Burn !?
By ticotaz in forum DVD & Blu-ray WritersReplies: 3Last Post: 16th Jan 2008, 05:23 -
Prototype HD DVD-R Writer seems to work fine.
By videopoo in forum Authoring (DVD)Replies: 3Last Post: 31st Dec 2007, 17:52
