  1. I have authored some dvd-r's using ifoedit and they play fien on my cyber home adl528. However when I came to disc to disc copy these masters my pioneer DVD-rom DVD-117 wont recognise the disc (on either datasafe or white label's). They also wont read in my PS2. I have authored with spruce up in the past with no problems such as these. I want to copy spiderman but when I input my m2v file ripped with smartripper I get an error at about 67% of the import sayin "temporal gop out of sequenece" or something like that.
    Can anyone help solve these problems?
  2. solved.
    need video_ts.vob file in final burn for ps2. any will do but it must be a proper one and not just a renamed file. Ifo edit does not create this file
    Apr 2002
    Australia
    hmmmm.....IFOedit will create the VIDEO_TS.IFO file which "should" be all you need.....the VIDEO_TS.VOB is usually some sort of intro or something.....however, whatever works is good also.
    Strange problem though.....anyone else have any thoughts ???
  4. this is the magic file for ps2 for some reason. woulndt read on my comp pioneer dvd-117 as well before i added it. It is created automatically in spruce up but not in ifo.
  5. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Normally you only have to re-save it in IFOedit, thats the clue.
    The .IFO files conatin directory-structure and other related infos about the .VOB files. The .BUP are just the backups of the .IFOs.
  6. I done Spiderman this way
    I copied ifo's and movie vobs using dvd decryptor and then run thru ifoedit to strip the vobs of stuff i didn't want, then ran get vts sectors and then burned it.
    This might help with the GOP error
