  1. I have a 3200x2400 jpeg...Needless to say the quality is excellent...I want to transform that jpeg into a menu, so I tried encoding it using tmpgenc at cbr 2500 (thinking it can't hurt to put it so high since its just an image and the size won't matter that much) but the end result was a distorted image, barely visible, all blury...So I tried re-encoding it using 6000 kb/s, the same thing...
    Then I tried using VcdEasy, same thing, bad quality...Am I doing something wrong here?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    send me the jpeg and the lenth you want the menu and if for svcd or dvd and i will make it for you
