I captured some video from my VCR using an AIW 32MB APG card. Using MMC using SVCD settings. I burned the file to my CD-RW using NTI software. which works great but the playback quality looks like a VCD. What tips can anybody give me to be able to capture SVCD format and make it look like SVCD. what does a good capture depend on??????
Your capture relies mostly on the source as far as how the quality can be. the best way to capture is use vdub w/ huffy codec to capture as AVI (this will be a huge file) then use tmpgenc to convert to SVCD.
But what if the source looks good and the captured and played back on the PC looks good. but the final SVCD burn looks bad...is it still the source????
any setting to be made within vdub w/ huffy codec to get a good SVCD???
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 18:49 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 01:42 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 13:13 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 10:56
