I couldn't figure how to make Nero burn the file after I convert from .AVI into .MPG using Tmpgenc. Nero wants me to use the Video_TS file, something like that so how do I do it? If I can't do that, I'm willing to try any software that allows me to author and burn a MPEG to a DVD so do you have a suggestion which software I should go for?
Your input would be greatly appreciated.
Thanks!
There is a new Nero plugin called something like NeroVision express that can author and burn to DVD but from what I hear it will only use its own codec.
Basically you need to author your DVD before getting Nero to burn it (or have the authoring program burn it). There are several apps to choose from for this from Ifoedit (free but limited) SpruceUp (trial version only), Ulead products, Sonic productsetc. They vary in price from a few $$'s to several hundreds of $$'s all the way to proffessional systems costing in the thousands. You make your choice and go from there.
I suggest you take a look at the authoring section listed on the left of this page. There are guides there to using several of the more poular programs.
Can I burn a .mpg file to a DVD
By robrpb in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 20:56 -
How to burn a mkv file to dvd with dual audio and subtitles with nero.
By drkcloud in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2008, 03:48 -
Burn MPG file onto DVD
By geek2330 in forum Newbie / General discussionsReplies: 15Last Post: 2nd Oct 2007, 08:51 -
Please help - >6gig mpg file 2 hr video - need to burn to DVD
By patplh in forum Newbie / General discussionsReplies: 17Last Post: 15th May 2007, 16:16 -
Trying to burn a mpg video file to DVD
By bhxtyrant in forum Authoring (DVD)Replies: 8Last Post: 11th May 2007, 14:22
