  1. Can anyone tell me how to make ifo edot 0.95 make the movie begin at chapter 2, without getting an illegal navigation error. Thanks in advance.
  2. If you use Spruce Up then i can guide you, If not i'm not sure, Sorry,
  3. I dont use spruce up, i use ifoedit and strip all unwanted streams out, then if the vobs are too big i use rempeg then ifoedit again. The film in question is minority report, the first cell is not a chapter but when ifoedit has stripped getvts etc etc it makes this cell chapter one.
  4. If you wanna go straight to the dvd menu open video_ts.ifo and in the top window click on VMGM_MAT..click the plus sign...then click on First Play PGC. Now, go to the bottom window and scroll all the way to the end..you should see 1.Pre Command there almost all the way at the end..right click on it and click on edit. It will give you some options..for the menu you want the command (Jump_VTSM) Jump To Titleset Menu. Then for Title Nr. it would be title number..hehe which is usualy 1 and under TitleSet Nr it would be the VTS your menu is located and finally for Menu you would select root. This so far has been the only way I know of getting around the damn trailers that wanna play at the begining before it hits the menu..hehe. I rip them and it gives me errors when it gets to that point. Hopefully this was what you were asking for I just got this from a site and tried it. I'm pretty new at this...only been doing it for a few weeks.
    -EBZ
  5. Oh, and there's also (Jump_TT) Jump To Title and put in the title you want in title number to go right into the movie..there's lots of other command that I haven't messed with..like I said, I only know these from reading off a site. hehe
  6. Thanks i will give them a try
