Hi,
I need some help to select a right capture card to convert my Hi 8 video ( From SONY TRV 608) to VCDs.
My System configuration is 800 MHz PIII 256MB RAM.
I am very tight on budget (maximum I can afford is US $75)
What are the fetures which are required to capture a good quality video and burn it to VCD ?
I use Nero to burn VCDs.
Is real time MPG feature necessary to have good quality Videos ?
Time is not a issue for me. (I can wait couple of hours for the machine to encode).
Can anyone please suggest a Video capture card which fits my budget ?
Regards,
Venky
No, you will most definately get a lot better quality using a software encoder.Is real time MPG feature necessary to have good quality Videos ?
Are you sure you want to create VCD's? IMHO VCD and good quality should't be used in the same sentence. I would rather make SVCDs, if your player just accepts them. -
Yes, my DVD player plays SVCD also. Basically I want to be able to get a good quality MPEG so that I can burn it as VCD/SVCD/DVD.
Regards,
venky -
I am in the same situation as venky_m. I want to transfer some Hi8 videos of weddings and outtings onto a SVCD or VCD but I am stuck as to what to buy.
I basically want something that has everything I need, fairly easy to setup and won't encounter the dreaded audio/video sync dilema.
I have looked in to the Canopus ADVC-50 and just read some reviews on the Pinnacle Studio version 8. Of course I'd like to get the ADVC-50 but at $300CAD (canadian)
and then I'd have to purchase a firewire card, it gets pretty expensive.
The Pinnacle looks to be a good alternative with basically everything that you need to start capturing and editing right away.
So my questions are:
1. Is there anything else out there that someone would recommend that's an "all in one" package?
2. If there isn't, is the Pinnacle "kit" a good choice for someone who converts video on occassion?
Thanks -
Hi,
I am in exactly the same boat..
I have a Sony TRV 740 D8 camcorder..
and want to convert my D8 tapes into SVCDs for archival purposes.
I would like to convert them into DVDs.. but DVD writers are still
too expensive.. will buy them only if they come under $100.
until then. i will be satisfied with SVCDs.
want an easy solution.. don't need to do any big time editing...
just something that will take everything from my 1 hr D8 tape
and burn it onto CD-R disk.
whats the best solution for this ?
Pinnacle Studio Version 8 is now available for $70 (after $30 rebate until Jan 31 2003 from various internet sites)
can some experts give me a clue as to whether this is the right solution or is there an easier solution..
thanks -
Well, for a low budget ( < 100$ ), the best chance goes to the digital camcorder using Firewire link since the capture is flawless, it preserves the original quality, I use this even with Pentium2-266 Mhz system with 64MB RAM. Capturing with analog cards will cause some level of quality loss. The Pinnacle DC-10 ( < 100$ ) could do the job here but beware that you need a pretty powerful CPU to capture at high quality.
In both cases, the hardware you buy is just for capturing and editing with the accompanying software (Studio DV 8, a good one which I use a lot).
Just don't use this software to convert to VCD, the quality looks horrible.
Use TMPGEnc (free software) instead. Due to long conversion, I have upgraded my system to Athlon 1.2GHz + 256MB RAM long time ago.ktnwin - PATIENCE
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
