Has anyone heard of or used this software. It claims to make a 1 for 1
copy of a DVD to a DVD-R. Is this type of software and what it is using,
legal to make a backup? Check this site, www.dvd-cloner.com
This is the first I have heard of it. Sounds conveinient if it does what it
claims. I'm skeptical at best, but it does have a trial download.
i have just purchased the full programme it takes around 3 hours to do a movie sometimes you have to use 2 dvds and also if you use dvd+r you have to make an image first then burn with nero will let you know when i have backed up pearl harbour mate
ya it will make a i on i copy as long as its under 4.7 gigs otherwise it has ti be split up onto two dvds. nothing special. its a rip off you can use other tools that are free that dose the samething and is faster..........
Blue-Cloner software - who's tried it?
By Express1 in forum Blu-ray RippingReplies: 12Last Post: 21st Feb 2013, 18:52 -
DVD Cloner
By tarzan54 in forum Blu-ray RippingReplies: 8Last Post: 12th Sep 2011, 08:45 -
Blu Cloner Blu Ray Backup
By pepegot1 in forum Authoring (Blu-ray)Replies: 8Last Post: 24th Apr 2011, 22:26 -
No audio with DVD Cloner VII
By obadia in forum Newbie / General discussionsReplies: 3Last Post: 30th Sep 2010, 03:46
