Hello all great site hopefully with the help of this place i will be able to backup my dvds and if you can teach me your allready a winner![]()
Ok so its a simpile question, i want to burn the best qualatie for my dvd backups,what are the best programmes i could use, at the moment i have smart ripper just to rip the dvd
but does that mean it will rip them to svcd format?
Anywhos at the moment all i want to do is get a full dvd on my hard drive with chapters and all in svcd format, i want to get it to the stage were its ready to be burned on a CD. But not after that all im intrested in is getting it ready to be burned.
ok guys and galz ill pop back on later and see whats up.
so the guy punched me, and later i stole his parrot as way of revenge
well keep up with with ripping the dvd to your hard drive. as far as converting to scvd with subtitles you should get dvdx. it coverts. splits to cd size and supports subtitles. heres the guide also for using dvdx. http://www.vcdhelp.com/sefy/?id=direct1.html
once that is done you can use nero to burn if you have it but if you don't and don't want to pay for it you should get Vcdeasy that can be found at http://www.vcdeasy.org/ which is free. hope this is a start..... -
cheers moite.
Yeah thats a good start thankyou.
Im on my way hi pip horah
Obsolete tools?
By takearushfan in forum Newbie / General discussionsReplies: 15Last Post: 15th Jan 2011, 15:20 -
Looking for Mac Tools
By robert_aronson in forum MacReplies: 3Last Post: 21st Oct 2008, 01:21 -
Fuoco Tools
By aicram in forum LinuxReplies: 0Last Post: 17th Jun 2008, 14:34 -
PC Tools Firewall Plus ??
By ofield1 in forum ComputerReplies: 8Last Post: 18th Mar 2008, 15:08 -
Multithreaded Tools
By jpc82 in forum Video ConversionReplies: 4Last Post: 25th Sep 2007, 14:13
![Computer details: win xp
thalon 1800xp[true1500]
80gb IBM. 9Gbmaxtor:]
256sdram
hercules 64meg
whut?
soon
N/A
pioneer ??
N/A soon
N/A
KT3 ultra2
inbuilt soundcard on motherboard Comp](/images/buttons/computer.gif)
