What are some ways to merge multi audio (mp3) into one audio file (mp3)? My photo slideshow can only play one song per album? If I have a lot of photos in one album then the photos will flip through really fast b/c it sync w/ the length of the audio.
Thanks,
Ames
Results 1 to 10 of 10
Why not use Gold Wave to copy and "Paste At-->End"?
Hello. -
Is Gold Wave a free ware? I see on the bottom on the screen a "toll: $"
Or it's a pay donation kind of thing?
Anyways I was able to merge the 2 song into one w/ no problem...thank you very much.
Got a quick question. What is the quickest way to skip around the track so I can listen to the song to review it? The fastforward buttons are too slow.
thx.
Amy -
Gold Wave is shareware. The toll is an indicator of how much the programmer feels the program is worth to you. You can still perform up to 150 commands before having to reload it. You can remove the toll and 150 command limit by paying the registration fee. I do not know how to advance to any part of a file, sorry.
Hello. -
To advance to any point of the song using goldwave, just click at the status bar anywhere you want and press play.
There's also a freeware <<MP3 Merger>> which does the trick and it works fine for me. Thanks.
cool...found the status bar...thanks gadget!
I'm going to chk out MP3 Merger & see how it compares w/ goldwave. thanks huiwinsun!
Amy
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 03:18 -
MP3 - Batch export song number/song title/etc to ID2/ID3 ?
By ralf07 in forum AudioReplies: 5Last Post: 3rd Mar 2012, 01:51 -
A time-lapse video that writes the words to a song as the song plays
By radardetector in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2011, 22:09 -
making video of song lyrics, and adding a song...how?
By snafubaby in forum Newbie / General discussionsReplies: 6Last Post: 15th Mar 2010, 03:09 -
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 22:16
