ok, ever since i've had this Pioneer DVR-104 I have had many problems burning dvd's. The software that came with it, doesn't record to the drive, and if it does, it fails half way through. I have firmware 1.31. No dvd burning software works with this burner, they all create coasters. I'm losing my mind trying to figure out what to use to burn. My dvd writer came with Sonic MyDVD, Record now DX, Archsoft Showbiz, and none will work. If anyone can give me some help here I'd appreciate it.![]()
"In my world the grass eats the cows"
Use the latest version of Nero and you should be ok.
I have a 104 and have always used Nero without any probs. -
try going to stomp recordnow website to get the latest driver see if that fixes it...I haev seen recordnow dx fail to detect a newer cd burner..so check their website..
just my .02 cents -
What kind of error are you getting when the write fails?
Sounds to me like it may be a hardware configuration issue..
First, make sure you are trying to burn at 1x until you can figure it out. Next, make sure that the DVD Burner is not on the same IDE channel as any of your hard drives.
I would put it on IDE2 Master if at all possible
Wits end with DV to 'anything' conversion
By video_noob in forum Video ConversionReplies: 23Last Post: 15th Aug 2010, 00:06 -
Burn DVD using DVDFab end result one file in iTunes?
By Kramer620 in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:26 -
I'm a wits end with HD PVR and the .TS files
By tvconfuse in forum Video ConversionReplies: 0Last Post: 19th Oct 2008, 12:56 -
At wits end - Capturing with ADVC-100 and audio levels are extremely low
By Towncrier in forum Capturing and VCRReplies: 13Last Post: 18th Sep 2007, 18:04 -
Low End Video Card w/ adapter vs. Low End DVD player
By enter8 in forum Media Center PC / MediaCentersReplies: 6Last Post: 20th Aug 2007, 15:45
