i have a movie in avi and it's 205mb. when i use tmpgenc it says it can't open it or it doesn't support the file.
i have downloaded some movies form kazaa and i tried to convert it using TMPGEnc and nothing worked. you might try going to mpeg tools and try multiplex it but i doubt i will work. i basicly had ended up deletiing it because i was so frustrated with it.....
Try this in tmpegenc:
1. goto option/environmental settings...
2. click the "vfapi-plugin" TAB
3. Give "Direct Show File Reader" the highest priority, (lower others if you have to)
That tells tmpeg to use the directshow filter before the others, you should now be able to read/encode anything you can play in the Windows Media Player. -
...or, if TMPGEnc still refuses, try to open the AVI in VirtualDub, and then frameserve to TMPGEnc. This detour has no negative impact neither quality nor encoding timewise.
/Mats
Pls Help convert my 3gp file to mpg or avi
By Nanflexal in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 16:58 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
How do I convert an mpg file using AC3 to use MPA instead?
By bmoret in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2008, 10:19 -
How to convert an mpg file to avi
By spyros in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2008, 16:02
