Hi,
I wonder if it would help to re-encode the standard vcd file (1150 b/s) to a higher bitrate say 2000 b/s with TMPGEnc. Do you get a better video? I want to clarify that this is a conversion from 1150 VCD file to 2000 b/s XVCD file. I try it once and it does not look any better than the original vcd. Is there any conversion to enhance a standard VCD file?
you would need to reencode from your source, not from the VCD.
every time you encode, you'll lose qualitywhat are you askin' me for...
I'm an idiot!
Higher 2.0 AAC bitrate from Ripbot
By jntaylor63 in forum Blu-ray RippingReplies: 6Last Post: 3rd Nov 2012, 16:22 -
transcoding mp3 to higher bitrate questions
By spiritgumm in forum AudioReplies: 6Last Post: 28th May 2011, 16:46 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 07:57 -
By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 21:33 -
Will the quality increase if the bitrate is higher after conversion?
By Choppa in forum Authoring (VCD/SVCD)Replies: 16Last Post: 3rd Jul 2007, 09:23
