Alright i am trying to burn my first vcd from a divx file and am using virtual dub to make a .wav file. Is it a problem that the file ends up being 1gb??
All is fine... vdub has just taken the compressed soundtrack of the avi file and expanded it to a non-compressed wav file. This is so when you re-encode to an mpeg, your encoder won't encounter variable bitrates in the soundtrack (from the DivX source) that would probably cause audio synch problems.
A wav file that is 1½-2hrs long can easily reach sizes over a gig. -
Uncompressed PCM audio is approx 10mb/min so for a 100 min film the PCM wav file will be 1 gig.
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 14:24 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 14:08 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 20:49 -
Ripping DVD & Virtual Dub Problem...
By Chana1 in forum DVD RippingReplies: 7Last Post: 8th Jun 2007, 08:45
