I am sorry I am a bit of a newbie![]()
I have been having some trouble with my DVD player and playing VCDs. I think my problem is when I convert an AVI file to MPG to burn to a cd. I was looking into getting a DVD burner and was wondering if I would still have to convert an AVI movie to MPG to burn to a DVD, if that makes any sense.![]()
Thanks![]()
-Spyder
you can actually use DVD2SVCD to get the job you want done
it supports avi files and can convert to DVD
good luck!
it works for me ;P -
thanks. Is this a solution to my VCD problem? Mind you my DVD player does not support SVCD.
-Spyder -
Lots of avi files are already so so sources. Making VCDs out of them is only going to make them look a lot worse. I just hope you know what to expect... Lots of people like it, lots don't.
I have already made AVI files into VCDs. They look ok. My Real Question is do I have to mess with the AVI file to burn to DVD format?
-Spyder -
Oh yes, and the encoding time is a LOT longer if you want good quality.Originally Posted by Spyder
DVD is mpeg-2 at 720*480 (or 576 for PAL). Uses bitrates up to 9.8Mbps and takes a lot longer to encode from divx than VCD. You can use VCD resolution video with higher bitrates but the quality will be much lower.
www.vcdhelp.com/dvd -
You should load your "avi" into VirtualDub and let it check for errors before trying to convert to mpeg1 or mpeg2.
If this goes ok then I would convert the file with TmpgEnc and choose a template that fits to the target. -
Try the GUIDES for TMPGEnc and Virtualdub:Originally Posted by Spyder
AVI, DV, DivX, ASF, MOV, nAVI, SMR, WMV to DVD MPEG2
http://www.vcdhelp.com/tmpgencdvd.htm
Virtualdub
http://www.vcdhelp.com/virtualdubframeserve.htm
http://www.vcdhelp.com/forum/userguides/87270.php
http://www.vcdhelp.com/forum/userguides/110082.php
http://www.vcdhelp.com/convert/avitovcdfoolproofusingcce/virtualdubframeserve.htm
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
