Greetings and Salutations!
I'm working on putting together a VCD for my employer. I've been testing it out, but am having problems on authoring the video clips. I'm using CDMotion to do the authoring and using the TMPGEnc program to convert my AVI's to MPG1's. When I'm compiling the clips I get an error message that I can't seem to figure out how to resolve. It's says "one or more audio packs exceed maximum pack size of 2304 bytes." Does that mean I have to lower the bitrate of my audio? If so, using TMPGEnc, it won't allow me to change the bitrate unless someone knows of a way around it. Could anyone help me out? It would be greatly appreciated!!![]()
I have never used (or heard of) CDMotion, as I use Nero and/or VCDEasy to do my authoring. I would suggest getting Nero and try it.
Also, if you want to screw around with the audio bit rate in TMPGEnc, you need to load the unlock.mcf template and it will open up everything. The unlock.mcf file is located in the extra folder. Just click load, find the extra folder, and double click on the unlock.mcf file. Then click on setting, audio, and you can lower the audio bitrate. But don't go below 160 or it will sound like crap. -
I've used CDMotion and I personally think that it is a poor effort. Also, I'm pretty sure that this program got discontinued years ago.
I suggest that you try VCDEasy.
Regards.Michael Tam
w: Morsels of Evidence
Need help authoring DVD from VCD mpeg files with dual audio..
By siratfus in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2010, 04:31 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 17:04 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30 -
Follow up : audio problems with VCD authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jun 2007, 18:34 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 11:20
