  1. Can some one please tell me what FILE SPLIT is for, and how do i determine what to set it to.
  2. i'm not too familar with the new Clad's...but i'm guessing the file split option is how you would like to split up the vobs when you rip them from the DVD disc to your harddrive. normally, you should split by every vob file, but i'm sure there are instances where you would like to split differently (i.e. i've heard if you wanna directly input the vobs into tmpgenc, you should rip the vobs into one big file onto your harddrive)
  3. That sounds like it could be right. I'll just test it out.
    thanks...
