Hello again
I was given a recommendation on how I could join two halves of a movie by using GoldWave (see: http://www.vcdhelp.com/forum/viewtopic.php?t=128389). And probably because I've never used
the program, I can't seem to find any "joining" commands.
Is anyone familiar with the program that can point me to the commands necessary to join to .wav
files?
Results 1 to 9 of 9
Why doesn't this work?
Sure. Open the first file you want to be the beginning. Then open the second file. Copy the second file. Select the first file. Select Edit-->PASTE AT-->End. Voilá!
Hello. -
Thanks guys, I'll give it a try!
____
Great, it worked like a charm! Now how do I get the video halves joined?
You mentioned doing it in TMPGEnc, but it only mentions MPEG 1 or 2.
These are two AVI files.Why doesn't this work? -
Vitualdub.Originally Posted by Turk
This will do the audio and video together -
Sorry Bugster, but you need to read the link from the original post.Originally Posted by bugster
Thanks anyway!Why doesn't this work? -
So I have read that now and understand your problem. What I suggest is this.Originally Posted by Turk
Open Avi 1 in goldwave, save out the audio as uncompressed PCM at whatever sample rate is needed for your final destination. (i.e 44.1 or 48khz).
Repeat for avi2.
Open avi 1 in virtualdub. Select Video->Direct stream copy, Audio->wav audio and select you avi 1 wav file from the step above. Now do file->save avi and save out a new copy of your avi with uncompressed audio.
Repeat for avi 2.
Now open avi 1 with uncompressed audio in virtualdub. Select file->Append Avi segment and select avi 2 with uncompressed audio. Check that video-> direct stream copy is set and audio->direct stream copy is set. Then select file-> save as avi and save this as a new file.
You now have one large avi with uncompressed audio ready for encoding etc however you want.
I know its a bit long winded and uses a lot of disk space but its straightforward and it works.
Hope this helps. -
I'd like to take this opportunity to thank all of you for your help.
Thanks to Tommyknocker, I've learned a new program, Gold-
Wave.
But a big thanks goes out to Bugster for coming up with a great
tutorial for my little problem. Bugster, it worked just like you
drew it up. Although I did substitute VirtualDUB for removing
the audio, the rest I followed to the letter.
So now, instead of having a moving on two CD's with bitrates
below 1300, I've got three CD's that have bitrates above 1900.
And the quality if superb!
Thanks again Bugster.Why doesn't this work?
Goldwave / AC3 problem
By andyellis in forum AudioReplies: 3Last Post: 30th Dec 2009, 00:27 -
goldwave help
By natty in forum Newbie / General discussionsReplies: 12Last Post: 14th Jun 2008, 02:28 -
goldwave help
By natty in forum Newbie / General discussionsReplies: 16Last Post: 23rd Feb 2008, 03:12 -
goldwave
By natty in forum Newbie / General discussionsReplies: 3Last Post: 16th Feb 2008, 06:25 -
looping a track with Goldwave
By thecrock in forum AudioReplies: 2Last Post: 1st Jun 2007, 23:59
