I thought I had this figured out. At a high bit rate you hit the 4GB mark at about this point.
I am still using WIN98SE.
I am capturing at 4000 vbr and everything stops in this time frame, even with only 2.9 GB mpg file.
I am using the DVC II card and TWNH to capture. I am trying to make a backup copy of a DVD by playing and capturing (vob files total 6 GB plus so digital copying won't fit). Resulting quality is still great.
This worked last week recording a 2 hour show off the air.
Anyone know the secret ??
http://www.spawns.dk/svcd/Index.htm
go there for fix files, and updated drivers -
VFW video for windows has a bug in it that causes this
since M$ has quit support for VFW
if your card uses VFW that could be the culprit -
Thanks for the replies.
I found a work-around, so it becomes an academic question for me.
Using TWNH I can capture 8 - 15 minute segments and use the video editor in Moviestar to glue together the 8 mpeg files into one two hour 3.9GB mpeg file. By using 720 x 480 during capture I am then set up for rapid processing by Dazzle's DVD Complete.
Capture Short Video Clips From 1.5 Hour DVD
By Grassman in forum Newbie / General discussionsReplies: 2Last Post: 27th Mar 2012, 01:52 -
Dropping one single frame in a two hour capture?
By justin81 in forum Capturing and VCRReplies: 5Last Post: 13th May 2010, 10:38 -
Limited capture success with Pinnacle MovieBox Plus 510-USB device
By ccooper in forum Capturing and VCRReplies: 4Last Post: 17th Jul 2009, 12:52 -
Capture, Burn, Distribue in same Hour
By hap123 in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2007, 01:18 -
Only recorded 30 minutes on a 60 minute tape, can't capture
By kyroha in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 11th Jun 2007, 10:40
