  1. can anybody tell me why anything i play is green and distorted with xvid
  2. Member Conquest10's Avatar
    Chicago, IL
    you don't have the codec.
  3. i have installed the codec but the picture is still distorted
    Jan 2002
    Manchester,uk
    install ffdshow, use search next time this has been posted many times
  5. when i try to install ffdshow i get an error saying error opening file for writing c:\windows\system32\ffdshow.ax
    universe
    did you regserve32 the .ax file into your registry?
    Aug 2002
    England
    Hi
    What codec you got installed?
    Is it one from a pack ??
    I had the same problem before installing this codec.....
    http://www.filemirrors.com/search.src?file=XviD_Install.exe
    Let me know if it solves the problem.
    Fozzee
