  1. I wanted to find out if any of you would know the answer to this problem. I have a dvd rom on my computer and for some reason when i insert a dvd into it, nothing happens. The computer seems to show the drive is there but the light blinks several times and then goes off. When I try to go to my computer and click on the E. Drive (dvd rom), it tells me to insert a disk when there is one in there already. Any help would be appreciated!
  2. had the same problem last night,i had 4 dvd's and only one of them would work with the dvd rom.they worked fine in my dvd player.
    since i didn't have any cd/dvd cleaner i just ran some water on them and used TP to dry them.
    if you try it,dont wipe in a circle,go across the disk and use something soft so you dont scrach the disk.
    well the three disks worked after wards.
    if cd's wont work then you have some other problem.
  3. I guess I have another problem. Nothing happens with cds and dvds.
