Hi, I got this AVI of MEmento which when I try to make a VCD or SVCD I can`t get the audio to sync, I have tried Vdub and Goldwave but both are out by a few seconds.
Anyone know a way around this or should I just watch on my PC
Thanks Doot
I have exactly the same problem with Memento, straight from Kick off the sound is out of sync, but the original avi file looks (and plays) fine.
What you need to try is in TMPGenc when you select Source Range in Advanced properties, do a 30 second clip. Now view that clip and see how many seconds you think (trial and error guesswork here I'm afraid) the sound is out of sync.
Now go back into TMPGenc and Source Range again, at the bottom you will see the option 'Audio Gap Correct', this is in Milliseconds, so if you think it is 3 seconds out, you need to put in 3000.
Give it a go, it might take a while getting it bang on, but it's worth it coz Memento is such a classic film!
Good Luck!
DV Type-1 to Divx video/audio sync problem.
By cgmarsh in forum Video ConversionReplies: 0Last Post: 10th Aug 2010, 15:35 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
MPEG to Divx audio sync problem
By starless in forum ffmpegX general discussionReplies: 8Last Post: 11th Oct 2007, 04:38 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 13:34 -
audio sync prob AFTER burning !
By bluraid in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 05:28
