  1. I have been trying to copy a pal DVD which is interlaced and have been unable to find an answer on how to correct the interlace problem. I have asked the question on quite a few forums but it appears that it cannot be done, or if it can no one is willing to tell me how. If anyone knows and can spare a few minutes to type a reply I would be very grateful.
  2. Member Treebeard's Avatar
    Aug 2002
    What part cant you do? whats going wrong with the conversion
    May 2001
    What makes you think that your movie is interlaced? How did you verify this? All DVD's are sent to the TV by fields (2 per frame). Are you saying that your DVD is a hybrid (ie, contains both FILM and NTSC content)? Or, are you saying that your DVD had some pulldown (24:1 ?) applied to bring the 24fps film up to 25fps for PAL? Some of these scenarios can easily be fixed - others (ie, hybrids) are not so easy.
    Perhaps it would help if you told us what DVD you are trying to apply your "fair-use" rights to.
  4. Thanks for the replies guys
    The problem I am having is when the DVd is played back on a TV any movement in the movie results in jerkyness.
    I have run it through DVD2AVI and Bitrate Viewer both tell me its interlaced. Here's what Bitrate viewer reports
    Num. of picture read: 9010
    Stream type: MPEG-2 MP@ML VBR
    Resolution: 720*576
    Aspect ratio: 4:3 Generic
    Framerate: 25.00
    Nom. bitrate: 9600000 Bit/Sec
    VBV buffer size: 112
    Constrained param. flag: No
    Chroma format: 4:2:0
    DCT precision: 10
    Pic. structure: Frame
    Field topfirst: Yes
    DCT type: Field
    Quantscale: Nonlinear
    Scan type: Alternate
    Frame type: Interlaced
    Notes:
    The DVD is Gimme Gimme Gimme a BBC DVD.
    May 2001
    Just use a different dvd ripper. There are a bunch like dvd decryter and smartripper.
