I am following the guides here to make vcd, but when i try to make a wav file using virtuel dub i am getting an error message, Saying that the requested audio compression not is compatible with the input format.
In file information I can see that the audio stream compression is unknown (tag 0055).
I have made vcd movies before, so what is wrong ?
You are missing a codec. find and download a program called gspot. Open your avi in this program and it will tell you what codec you need. You can then install the codec and everything should be fine.
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 13:38 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 16:26 -
Adding audio (wav) to video (avi) (want to delay start of audio)
By Lanton in forum Newbie / General discussionsReplies: 2Last Post: 12th Apr 2010, 13:50 -
audio conversion problems? (wav to ac3
By just in forum Newbie / General discussionsReplies: 9Last Post: 28th Oct 2008, 19:35 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 18:27
