I am having trouble and could use some help. I am trying to take a 10 minute clip that i already edited and rendered as a .avi file and now i need to break it down into 5 two minute .avi clips. I can do it the long way by using a program like vegas video, importing my full clip, highlighting 2 minutes then rendering it again, but its a time consuming project. I have spent the last 2 days looking for other options, one of which is virutaldub, but when i go to open my original file i get this error:
couldn't locate decompressor for format "dvsd"(unknown)
VitualDub requires a Video for Windows(VFW) compatible codec to decompress video. DirectShow codecs, such as those used by windows media player, are not suitable.
If anyone has any thoughts or ideas, it would be greatly appreciated.
Please respond here, not in email.
you don't say what format of file you are trying to cut?
if its mpeg2,try bbmpeg.
guide here: http://www.vcdhelp.com/forum/viewtopic.php?t=119181
Virtualdub and cutting precisely
By silverwolf0 in forum Newbie / General discussionsReplies: 16Last Post: 2nd Jun 2023, 05:39 -
Cutting video sections with Virtualdub without recompressing
By rantpolicy in forum EditingReplies: 11Last Post: 16th Apr 2012, 06:48 -
converting from 30i to 30p with Virtualdub; before or after cutting?
By CFPJer in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 22:17 -
problem with cutting AVI in half with VirtualDub.
By eroy in forum EditingReplies: 1Last Post: 27th Dec 2007, 06:53 -
Is there not something better than virtualdub for divx cutting?
By pondleaping in forum EditingReplies: 23Last Post: 5th Jun 2007, 11:45
