Using Virtualdub for capture (huffyuv compress) , TMPGEnc to encode the *.avi file to *.mpg file, Burn with VCDeasy as an SVCD1.0 for the CVD. I have been successful with this.
Now I want to do divx but unclear on what the guides tell me. I want to make divX CD's that if I want to I can go to CVD/DVD later. From reading it seems like I may not have enough PC speed to do real time divX cature with virtualdub. Here are my questions:
Is it possible to capture as I have been using vitualdub and then convert the *.avi I get using huffyuV to a divx *.avi (or can I encode the captured file directly to divx mpeg4 format?
How do I take my resulting capture *.avi (either captured directly with divx codec or converted huffyuv captured *.avi to a divX *.avi and burn this file to a CD? What is the equivalent of TMPGEnc for divx? What Burn program I don't see divx in either VCDeasy or Nero (maybe I don't know what to look for)?
EDIT: A real newbie question. The bitrates for the divX look very low compared to the CVD so does that mean that if a divX is later converted to an SCVD/CVD/DVD that this too will be low bitrate and horrible?
Also The cd's that I want to burn are for use on the PC. If I later convert to SVCD that is for the TV so that is why I want to know how to do both formats.
Results 1 to 1 of 1
divx 2pass encode error
By ledishis in forum Video ConversionReplies: 3Last Post: 4th Apr 2012, 14:47 -
burn in a subtitle in Xvid without re-encode
By Cazz in forum SubtitleReplies: 6Last Post: 2nd Sep 2011, 23:28 -
Firewire capture - Encode on the fly?
By BruceLEET in forum DVB / IPTVReplies: 1Last Post: 30th Aug 2009, 17:45 -
How to encode DVd to DIVX with gui4ffmpeg
By gui4ffmpeg in forum User guidesReplies: 32Last Post: 21st Nov 2008, 04:02 -
ConvertXtoDVD to encode and burn video files to DVD
By crowheart in forum Video ConversionReplies: 15Last Post: 16th May 2007, 22:50
