CCE
    Dec 2002
    Michigan
    I am using CCE for encoding my dvd backups but when the encoding is done the files are too small so I am losing quality. I have not been able to find how to change this. For example I backed up full metal jacket and it was only 2 gigs. Any ideas would be nice
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    raise the bit rate -
  3. use DVD2SVCD (on the left under tools) as an all in one DVD to CVD conversion. Its all figured out for you (very intuitive program). For how to guides, you can seach for a member by the name of baker. He has a very good easy to follow VISUAL guide.
    Sep 2001
    N/A
    heh heh!!!
    Nice to see I dont even visit this site anymore and I am earning bronie points!!!
    Baker
  5. Originally Posted by chadkan71
    use bitrate calculator:
    www.vcdhelp.com/calc
    Zzzzzzzzzzzzz
    Dec 2002
    Michigan
    My question is where to raise the bite rate. In the guide I got from here it never mentioned the bitrate
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    in CCE , bit rate - dont know what guide you are using but since your burning dvd -r backup (i assume) , and lets say your settings were 300 , 4000, 7000 VBR , and you only ended up with 2 gig file and know you can get 4.3 on a disk is to go with 300, 6000, 9000
    those numbers may not be what you have but are an example ..
    tmpgenc can be used to quickly find out the finished size at a certain bit rate .. then encode it in cce or tmpgenc or main concept , they all work fine ..
