but the problem i have it during playback in the program i cant get the sound and video to sync together..One is running faster than the other. I want to beable to make copies to enjoy on our dvd player...any help for this major noobie will be greatly appreciated.
how did you turn your avi into an mpg. that is where your problem lies. give us the steps you took or did roxio do it for you. I suggest using mulitple steps like using vdub - tmpgenc- then burn.
Im a little confused with terminology but let me try step by step...first i had to click on video impressions....then find the avi that i wanted to change ...then add to storyboard then play movie...then save as mped-vcd pal 352x288(*.mpg) then after about a half hour it was saved as that..but when i thought i could go ahead and copy I previewed the movie first and thats when i noticed the sound and video were not in sync..I hope i answered your question
to add to my last comment I really dont want to have to download any other additional programs for this because I had just spent quite a bit of money just on this roxio program.
From experience you would be best to do the following:-
1. Capture your video as you normally do.
2. Edit the footage - titles etc - and save as AVI.
3. Use the FREE TMPEnc encoder (found under links) to encode to PAL MPEG VCD.
4. Then use that mpeg to burn as VCD.
Hope this helps.TOMMO -
thanks tommo for responding...I went to your website and found the site for the download but do i download the most recent file?
It would deem that that is the only version that can be downloaded, so yes.
TOMMO
Roxio Media Creator Suite 10 Stange Results
By DB83 in forum Authoring (DVD)Replies: 7Last Post: 16th Dec 2011, 13:53 -
ROXIO Music Disc Creator 9 --- track Lists / Shuffle
By Trollheart in forum AudioReplies: 2Last Post: 11th Dec 2007, 17:10 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 16:27 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 16:27 -
Problem with Roxio Media Creator 9 and slideshow
By ingeborgdot in forum Authoring (DVD)Replies: 12Last Post: 30th May 2007, 12:58
