I was trying to back up Apocalypse Now Redux and I think due to the length of that film which creates an over 2.0 GB .wav from DVD2AVI it is causing some problems I have never experienced. TMPGenc says when it starts "Could not decode audio" or something like that and when I try and see if the audio works it is too large to play so I am not sure what is going on and thought someone may have experienced this when ripping something that is that long and large 3+ hours. thanks
happened to me on a lot of movies (i.e. titanic, green mile, and apocalypse now redux)
split the vob files into 2 groups and process them as if they were 2 separate movies....cut/join after you've encoded both groups separately, as needed -
Yeah that is what I figured I needed to do was to reduce the size of the files namely the audio part, and just us DVD2AVI to produce to separate projects and work on merging and cutting after the encoding. Thanks for the confirm.
Rip to one large file incl. subtitles
By Denkirk in forum DVD RippingReplies: 2Last Post: 20th Mar 2012, 11:45 -
how to convert and save audio & video files? how large of a HD?
By speone in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2012, 13:55 -
Copying a large MP3 audio file to 2nd CD-R once 1st CD-R is at capacity
By keypoints1 in forum MediaReplies: 10Last Post: 20th May 2011, 22:44 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 13:40 -
Problems with large (1 Tb) USB backup drives on older computers
By Toastie in forum Media Center PC / MediaCentersReplies: 10Last Post: 30th Apr 2009, 02:40
