  1. The DVD is 6.73GB, and If I could get out the Fullscreen version it would easily fit on a regular DVD-R. How can I do this, is there a guide on here for this specific method?
  2. I'll tell you how I've been doing it then I'll watch this thread to see if there is a better way. This method is very fast.
    Can't take credit for it at all:
    open up smart ripper
    go to movie
    go to stream processing.
    put a check in the box enable stream processing
    put a check mark in to box with the video and one in the box with the audio you want
    to the right of that click on demux to extra file. make sure you do this to both.
    once that is done you will have a m2v and sc3 file.
    now open ifoedit
    go to dvd author
    click on author new dvd
    import m2v and ac3 files
    ifoedit will make new dvds files
    burn them using whatever you use to burn dvd with.
  3. Doing this method can I use multiple Audio options and subtitles still?
  4. hey DTWells2k2..this may help.....Doom 9 (who kicks ass) hehe has a tutorial on how to remover the full screen version using IfoEdit if that is what you are planning to use...you can find it on hit site here:
    http://www.doom9.org/mpg/ifoedit-advanced.htm
    hope this helps!
    -EBZ
