I have a Canon Powershot A40. It has a feature to take a AVI video clip and I wish to convert this to a mpeg. I have tried the step in the newbie section. I have run the avi through LSX-mpeg encoder and TMPGEnc with no luck. Both times I got an error that the file type is not supported. It is only a 5 second avi clip. Cameras owner book describes the movie as "AVI (Image data: Motion JPEG, Audio data:WAVE [Monoaural]).
Does anybody have any suggestions?
u know wat man? i have the same problem too
i'm using canon power shot s45 and i was going to do the same thing but tmpgenc doesnt support motion jpeg
so have u found a good converter yet? -
cuppla Q's to clarify:
Do you have an MJPEG codec installed? There are a number of them, and they're not all compatible (Pic, Mainconcept, Matrox, Buz, AVID, etc)--which one is supposed to work with your files? Does the codec come on a software install disc?
Can you even play the file via WMP?
Do you have a video editing proggy that is known to work with those files? If so, I'd export from there into huffyuv or something.
BTW, I love your ID!
Scott -
u know wat? i found the codec on mainconcept's website
i install it and then open tmpgenc, and it works!!!!
free & easy~
*whose ID u r talking about? -
sorry trainspotter01,
yours is good too, but I meant "I.P.Nightly"
Grade school humor, I know, but some late nights it hits the spot. -
That's good news.Originally Posted by trainspotter01
Can you post the link to the site and which file you downloaded?
I forgot about this thread.
No response since Dec.
Thanks for replying. -
here u go dude! hope it helps
http://www.mainconcept.com/de/downloads.shtml
Recovering a corrupted AVI from a digital camera
By debest in forum Newbie / General discussionsReplies: 12Last Post: 20th Oct 2015, 06:34 -
Restoring Deleted AVI file from digital camera
By vroom_vroom in forum RestorationReplies: 3Last Post: 26th May 2009, 21:19 -
Convert AVI from digital camera to what format
By hemang in forum Video ConversionReplies: 14Last Post: 24th May 2008, 08:13 -
Convert Digital Camera avi's to smaller size
By nook in forum Newbie / General discussionsReplies: 5Last Post: 7th Apr 2008, 07:13 -
MOV to MPEG or AVI from digital camera video
By mtsalmela80 in forum Video ConversionReplies: 1Last Post: 19th Mar 2008, 17:24
