When we encode a source to say vcd there are a variety of programs that we use to achive this result. Everyone knows the outside of encoding, ie whoich programs to use and how to use them etc but what happens on the inside?
What does the video encoder lets say TMPGEnc actually do to the incoming source file, so that it can output the desired vcd file?
I got wondering about this when I realised that bad or un-decodable frames where to blame for many A/V sync issues and other problems. I know that most digital video files are compressed in some way, does the encoder mearly decompress it change it and put it out the other end as an mpeg1 file? or is it a bit deeper than this?
just a curious mind lol catch you around and thanks for your time
TLTw
The Hellsing family will purify this world...
it analyzes the video looking for things it can destory. it destorys all the light the human eye cannot see, and then it compresses certain images into Intra frames. It than compares the next frame to the I frame and eliminates anything that is the same.
it's all math. -
sounds like a visual equivelant of MP3, cheers for the post
The Hellsing family will purify this world... -
mpeg1 first takes the jpeg of each frame. jpeg compression changes the colour space from RGB to YUV (luminance and chrominance) then discards some of this information. the data is then transformed from the time domain to the frequncy domain with the discrete cosine tranform (aka fast fourier transform). the data is also truncated (rounded off) and quantitised.
as well as this, interframe redundancy is exploited ie, imagine a video of a person walking along infront of a blue sky - a lot of the data representing the sky will be the same since it's all blue. so the mpeg compression algorithm subtracts a frame from the previous frame and only stores the difference. this storing of only the difference saves heaps of space.
mpeg2 and 4 use a few more tricks
64 bit encoding program for MKV to MP4
By prk72 in forum Video ConversionReplies: 10Last Post: 30th Oct 2010, 15:11 -
Program to crop MP4 files without re-encoding
By milatchi in forum Video ConversionReplies: 3Last Post: 20th Aug 2010, 11:13 -
Program to split .mov files without re-encoding
By Guest in forum EditingReplies: 5Last Post: 21st Jul 2010, 21:09 -
Free Program For Creating Chapter Points In DVD Video Without Re-encoding?
By bbanderic in forum Authoring (DVD)Replies: 3Last Post: 7th Mar 2010, 10:17 -
SUPER converter program has Encoding Failure Error
By kerrex_2006 in forum Video ConversionReplies: 4Last Post: 26th Sep 2009, 14:44
