Have a problem Burning VCDs using Nero. When I drag this vcd mpg file over to Nero....theres an error stating stream encoding ehich is invalid for a [super]vcd.
Another problem occurs in another file: error says invalid audio stream 48000 hz two channels.
Any ideas how to fix these problems. Any help would be greatly appreciated.. thx
that means that your audio is 48khz, and for a standard VCD, it needs to be 44.1khz
what you do is:
demux your mpeg, change your audio to 44.1khz, remux, burn
look here for how to do the above:
http://www.vcdhelp.com/forum/search.phpwhat are you askin' me for...
I'm an idiot!
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
VCD burning freeze
By Douglas879 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 28th Nov 2010, 15:23 -
Burning .srt along with .avi onto a VCD
By wox in forum Authoring (VCD/SVCD)Replies: 3Last Post: 5th Jul 2008, 08:35 -
Help burning vcd
By Reds in forum Authoring (VCD/SVCD)Replies: 3Last Post: 8th Feb 2008, 07:20 -
vcd burning
By srckaimal in forum Newbie / General discussionsReplies: 26Last Post: 6th Dec 2007, 06:23
