okay after A LOT of research i FINALLY built a successful applescript studio project that will do the afformational mpeg-2->mpeg-2 in quicktime (blank pict, drag movie, export...) i was thinking for dvd downsampling it would be a nice option in afropic to be able to choose from mpeg2enc or qt mpeg-2 encoder since the qt mpeg-2 encoder is SO much faster. (DP 800 it re-encodes realtime or faster, stick that in your pipe and smoke it pentium) but my problem is, to keep the applescript program from hogging precious processor speed i have it ignoring application responses from quicktime so the script doesn't sit there with a color wheel till the conversion is done. the problem with this is i want to have it go from one process to another (re-encode video in qt, re-encode audio in terminal[obviously an optional step since ac3 audio is better], multiplex, build dvd folders) and since i would need to know when the video is done in quicktime before going on to multiplexing im kind of at a loss... i don't want to remove the ignoring application code b/c the applescript would be taking up too much of the system resources....there has got to be a better way... any ideas??
Results 1 to 1 of 1
As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind.
AppleScript Error _iframeflag is not defined (-2753)
By linea in forum ffmpegX general discussionReplies: 10Last Post: 30th Jun 2008, 13:46 -
An AppleScript to disclose various informations on video files
By houdini2 in forum MacReplies: 12Last Post: 22nd Mar 2008, 16:21 -
AppleScript Error
By stembridge in forum ffmpegX general discussionReplies: 5Last Post: 1st Mar 2008, 10:44 -
Leopard AppleScript Errors
By brittohalloran in forum ffmpegX general discussionReplies: 2Last Post: 2nd Jan 2008, 15:52 -
Question for NR gurus...
By takearushfan in forum AudioReplies: 11Last Post: 28th May 2007, 20:00
