hi
i capture in IUVCR (with Picvideo JPPEG codec) to SVCD specs - it all caps great no problem.. Because my drive is FAT32 i can only cap in 4GB chunks.. luckily IUVCR is capable of continous capping, so my cap may be like 3 seperate avi files.. is there any way you can create a project file (like you can with VOBs to d2v/wav file in DVD2AVI) that tricks TMPEG into thinking it is one big AVI file, otherwise i have to encode 3 sperate AVi files to MPEG2 then join em and burn. Essentially, all i'm asking is there a similair program to DVD2AVI that allows me to save a project file but for split captures in AVI fomat. Phew, hope u understood that.. thanks for the help!
You can use virtualdub for this and frameserve your files to Tmpgenc.
Open your 1st avi in virtualdub. The select file->append avi segment. repeat with the third.
Use this guide for more info:
http://www.vcdhelp.com/virtualdubframeserve.htm
convert "file type:file" to mp4
By ghola in forum Video ConversionReplies: 5Last Post: 3rd Mar 2012, 10:43 -
Need to supply "File Type" and "Mime Type" info for MKV file
By oneking in forum Newbie / General discussionsReplies: 9Last Post: 9th Feb 2012, 04:31 -
corrupted m2ts file - "cannot detect stream type"
By ac1j2 in forum Newbie / General discussionsReplies: 0Last Post: 4th Mar 2010, 08:51 -
The "convert a single VOB file to a DVD" project!! :)
By djdust in forum Authoring (DVD)Replies: 42Last Post: 23rd Feb 2008, 08:49 -
Audio files now show as "Winamp Media File" in file type
By tmh in forum AudioReplies: 3Last Post: 7th Jan 2008, 14:25
