  1. I have looked all over Virtual Dub for some setting or something that will tell me what a PCM wav is. Can anyone help. I am atttempting to use a new encoder (Xing) and it keeps telling me it will only accept a PCM wav for the audio. Thanks much!
    Jul 2001
    Brazil
    PCM (Pulse Code Modulation). It's a pure sound (digital sound).
    A sample: when you grabb your CD-music (from your Audio CD to the hard disk) you create a PCM wav file(or .wav)=> 44,100 hrtz. Other sample: NORMALLY you encode your .mp3 files from .wav files.
    Directly to the problem: NORMALLY almost encoders(like a Xing) needs to read a PCM wav file to encode it.
  3. Thanks for the response. Now it leads me to ask, how do I pull the sound from an avi and save it as a PCM n virtual dub? And if not in that program, what program do you recommend? Thanks again )
    Jul 2001
    Brazil
    Keybored,
    Now I'm just busy with my job. Don't you worry I'll be looking for a program (freeware if is posible)for you
    OR IF ANYBODY HAS A SOFTWARE NAME THAT READS .AVI (part of sound) AND SAVE IT IN .WAV, PLEASE INFORM HIM. TKS ALL.
    P.S: I don't use Virtual Dub.
    Jul 2001
    Brazil
    Hi Keybored,
    I found SOUND FORGE XP STUDIO 5.0 software.
    Go to: http://www.sonicfoundry.com/products/NewShowProduct.asp?PID=460.
    This software supports 17 sound files (import and export 17 sound files), include .avi and .wav.
    The price is $59.97. I don't know if it has a trial period. Go to that website and verify all about it. OK???
    Good luck.
  6. Banned
    Jun 2001
    UK
    http://www.goldwave.com has a great program, and the trail version is the same as the full version except for a serial number
    Also download the "Lame" thats on the site, then you can use MP3 as well
    Me
    You
    WHLVFP < hint
  7. Just use VirtualDub - load the avi, and choose "Save WAV" - insuring that in the AUdio section of VirtualDub, you specify "Full Processing", and "Save as PCM AUdio".
    Nothing to it.
