    Dec 2002
    up north
    ive got a pioneer 104 writer and a copy of dvd x copy when i start the program and select the longest file (this being the main film) and click on copy it get past this stage then there are three boxes the top box is target drive but my pioneer 104 does not appear in this box and the for the program does not get a further .please can any one help......
    Please don't cross post. One topic is enough.
    Have you checked http://dvdxcopy.afterdawn.com ?
  3. Did you install the gear drivers? Look under start- programs- the dvdxcopy driver install
    Apr 2003
    I'm having the same problem. Anyone figure anything out? I checked where Baldrick said to look & just found A LOT of similar problems (but no good new advice). I also tried what byrdmaniac69 said & the install drivers option just continuosly tells me to reboot my computer (it never appears to actually do anything). Anyone? THANK YOU!
    Dec 2002
    up north
    heyjjjaded
    the way i solved my problem was 2 instal the drivers 4 dvdxcopy and it worked dvdxcopy reconised my dvd writer being the 1.04... have u tryed updating the firmware of your 1.04 as this may help 2
    Apr 2003
    I think daxster is right, but I continue to try to install the drivers (START - PROGRAMS - DVD X COPY - CONFIGURE - INSTALL DRIVER FILES), but I still get an immediate window saying that several drivers NEED to be installed and that I should reboot my computer. I reboot and the DVD X Copy window automatically pops back onto my screen with the same 3 options (INSTALL DRIVER FILES, CHECK FOR UPDATES, or EXIT). If I select INSTALL DRIVER FILES, I am again just told that several drivers need to be installed & that I should reboot. It never actually (appears to) install any drivers ... just constantly tells me to reboot. HELP! THANK YOU!!
    Dec 2002
    up north
    have u tryed dvd2one its a brilliant program it takes around twenty minutes 2 make the files small enough 2 fit on a 4.7 gig dvd disc and its puts it all on one disc as well...
    Apr 2003
    Thanks daxster. I stumbled across a solution & now have DVD X Copy up & running again. Through the control panel, I restored my computer to its previous settings, back when I had DXC running (didn't know I could do that). Anyway, I am convinced that my problem had something to do with the trial version of Nero that I downloaded, istalled, used, let expire, and consequently removed from my computer. No problems now ... thanks!
